has anyone ever bent a swingarm or frame???
Old Sep 13, 2002 | 08:04 PM
LOCOMOFO's Avatar
my 2001 scrambler 500 4x4 was hit in the left rear wheel ,bending the axle and breaking the hub...I replaced the hub and axle only to notice that the axle is not parrelell to the bike!!!
The wheelbase on the right side is 1.5" shorter than the left side???
Is the problem most likely a bent swingarm or frame or both????
has anyone else had this problem???what was bent????
Thanks
Old Sep 13, 2002 | 10:51 PM
superkev's Avatar
Hey locomofo,
Have you tried adjusting the axle? On every quad I've seen, you can adjust the axle alignment with a couple of screws. And if you don't have a service manual, you should probably get one, they are a big help.
Old Sep 13, 2002 | 10:56 PM
LOCOMOFO's Avatar
yes i need a manual!!!!!
i dont believe there is any adjustment???
thanks
Old Sep 14, 2002 | 12:02 AM
SCRamfusED's Avatar
sorry for the bad luck dude, more than likely you probally bent your frame if you took a side hit or landing . I broke my swing arm a few months ago from jumping it too high. hopefully you bent your swingarm and not your frame. the rear part of the scrambler frame where the swingarm goes is pretty rigid.best luck dude!!!! later
Old Sep 22, 2002 | 04:09 PM
swampdonkeykiller's Avatar
I've got the same problem with my '01 scrambler 500 4x4. You can adjust it a little but not that much. My problem is a bent swing arm which is weird in that it is something that shouldn't bend considering all the gussetting on it- it should break or crack before it bends.
Old Sep 22, 2002 | 05:06 PM
bullgod's Avatar
I snapped my on my scrambler it never bent.
Old Sep 22, 2002 | 08:41 PM
EasterEgg's Avatar
I have cracked a weld on my 98 Scram before but they are weaker than the 99 and newer ones. They and ed the extra gussets when they increases the travel from 8.5 to 10.5.
I don`t think there is an adjustment. I would have to agree that the swing arm is bent over the frame. It most likely bent where it mounts to the frame. It`s the logical weak point during a side impact. HTH
Old Sep 22, 2002 | 08:44 PM
LOCOMOFO's Avatar
Thanks for all the info everyone!!!
I figured by the way the swingarm looks that it would never bend or beak??? but obviosly it does!!!
Old Sep 22, 2002 | 09:47 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I bent the frame on my 2001 Sportsman 500 by rolling it end over end 6 times down a hill. That is why I tell everyone to BUY INSURANCE. I have a new machine thanks to having bought the insurance.
Old Sep 23, 2002 | 12:30 PM
modquad's Avatar
There is not an adjustment on these machines (other than having a body shop frame rack, or other jig).
Ken
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
meddy0388
Sep 9, 2015 06:41 AM
