Stubborn Valve Collets
Old Sep 23, 2002 | 10:17 PM
ScoobyDFW's Avatar
Is there a trick to freeing valve collets that are stuck? I tried using a valve compressor that holds the valve seated and lowers the retainer, but the collets are jammed, preventing the spring compressor from compressing. I now use a different setup where I compress the spring but allow the valve to come off the seat. I use a plastic hammer to tap the valve to free the collets. I still have problems freeing the collets.
Any suggestions?
Thanks.
Old Sep 24, 2002 | 03:58 PM
Mudrush's Avatar
Use a socket or small piece of pipe with the inside bigger than the collet diameter. Wack the crap out of it two or three times and it'll break them loose. If you have the head off put a piece of rubber tire or something under the valve head to make the hit from the hammer more effective. don't go crazy with it but that will break them loose.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
