loose chain on 325 trailboss
Old Sep 24, 2002 | 06:02 PM
sportswoman400's Avatar
i have a 2001 trailboss and when i go in reverse the chain drags along the chain gaurd and snaps when i go forward it tightins up do i need to tightin up the chain if so how is this done.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Sep 24, 2002 | 11:53 PM
BubaHyde's Avatar
1.Loosen the Two Long bolts Holding the Carrier.
2.Also loosen the Caliper Bracket to Carrier Mounting bolt.
The whole Axle carrier assembly is like a Cam, Twist or turn it to Adjust.
Make sure you do not OVER TIGHTEN chain. There is a proper lash.
Tight chains only cause problems. Much added stress and wear.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
