Help with my rear brakes 400ex
Old Sep 24, 2002 | 08:41 PM
DEPALMA's Avatar
My rear brake pedal when I push it down it will not snap back up. i also disconected the screw from the master cylender piston and it still does not snap back up, I have to do it by hand. I think it is the cylender (located above the brake pedal) Do I need a new one or can it be rebuilt, or maybe this is not the problem. Before I go buy a new master cylender any thoughts would be great.
2002 400ex
k&n jet kit
w/b slip on
w/b bumper
Old Sep 24, 2002 | 11:54 PM
tprender's Avatar
Did you try spraying some type of oil in that area?
Old Sep 25, 2002 | 02:18 AM
BigWaynester's Avatar
First, try spraying that area (brake pivot point) with WD 40 or something. Work it in a bit, I think this will help.
Old Sep 25, 2002 | 03:34 AM
prang11's Avatar
Take the brake pedal out of the frame and replace the seals around it. Then sand the rust off the pedal pivot point and put some heavy duty marine grease on it. Then reasemble it. My buddy had this same problem. If this isnt it then i have no clue..
Old Sep 25, 2002 | 08:49 AM
MAZZ's Avatar
Is the spring still attached to the brake lever?
Old Sep 25, 2002 | 09:24 PM
Warrior1's Avatar
You may of gotten air in the line try to bleeding the brake.
Old Sep 26, 2002 | 09:15 AM
DEPALMA's Avatar
Thanks prang 11 The pedal had to be re-greased. I poped it out sanded rust and re-greased now it is perfect.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
