700 mods...results...wow!
Old Oct 5, 2002 | 09:50 PM
sporty500's Avatar
Hey Guys,
I haven't contributed anything in quite some time...
I was a little diappointed with the torque in high range off the line on my 700, the dealer advised me to change the spring in the primary to the white one. This made a noticable difference, but I wanted more. I've looked at the airbox intake and figured it could be opened up a little. I ordered an extra snorkel(in case it didn't work, I could put my old one back on) and cut the tube off at the square section, before it tapers down to the tube. I than fastened on a 2 1/4"ID rad hose with a clamp and scilicone, and tucked the hose up under the tank, where the old one used to be. I used about 6" of hose and I had to remove the foam insert that went around the two intakes.
The new airbox snorkel cost about $26 Canadian, I found a chunk of rad hose for nothing so it was a cheap mod.
Results...wow!!!!! It gave me alot more power in the low and mid range. I have two buddies with the 700's as well, and after I changed the spring in the clutch they were able to smoke me every time. With the airbox mod the tables turned. Now off the line I can get two quad lengths in about 50'.
Very happy with the results.
2002 SP700
2001 Dodge Ram
1991 Dodge Ram
Old Oct 5, 2002 | 10:39 PM
PolarisMech's Avatar
now ya need to mod your muffler, and buy a dual rate secondary helix..
and some lighter rims and tires if ya can afford it.
Old Oct 5, 2002 | 10:59 PM
sporty500's Avatar
I was thinking about the Helix, have yo tried one?
Old Oct 5, 2002 | 11:45 PM
alltoys's Avatar
Hey Sporty I now a couple of fellows in Wetaskiwin and would they be Rick and Graham perhaps with recent 700 purchases. I may now you myself if not let's ride sometime. Have fun talk to you again.
Old Oct 9, 2002 | 07:42 PM
SurferSam's Avatar
Default 700 mods...results...wow!
Did you have to re-jet? I didn't think the airbox mods helped much on the 4-strokes. But I guess the 700 might have been designed after the sp'500 airbox. If you have pics, I would like to see.
SurferSam
Old Oct 9, 2002 | 11:23 PM
sporty500's Avatar
I have a picture, but its still on the camera,(no digital yet). I didn't have to rejet, up here in Canada they seem to run a little rich from factory, we're at about 2600 to 2900 feet.
I didn't know if it would make a difference either, but, the amount of air it allowed in made a huge difference.
Old Oct 11, 2002 | 02:04 AM
alltoys's Avatar
Sporty if you are the one I can't waite to run with you and the gang come the May Long weekend. Have to see if your modds do you justice. If you want to do your muffler come up to my toy shop and we can modd it right here wont charge you a penny well maybe 2. Have fun.
Old Oct 11, 2002 | 08:00 PM
sporty500's Avatar
It works great, certqainly not like nitrous, but nice!
Old Oct 11, 2002 | 10:18 PM
MOUNTAINEERRIDER's Avatar
YOU WANT WOW TRY HOT SEATS SPEED KIT FOR 700 SPORTSMAN.I PUT TUNED HEADER,SILENCER ,CLUTCH KIT AND HOTSEAT AIR BOX MOD PLUS 210 MAIN JET.TALK ABOUT A ROCKET .I RIDE ONE WHEN ONE OF THE HOT SEAT PARTS DON'T BREAK.HEADER BROKE.THEY FIXED IT..SILENCER CAME APART I FIXED IT .THIS THING WILL REALLY SMOKE A STOCK 700..MY FRIENDS WILL TELL YOU THAT!! (THEY HAVE STOCK 700"S)
Old Oct 13, 2002 | 01:05 AM
sporty500's Avatar
Whats' the hot seat kit worth?
