braided brake lines
Old Oct 6, 2002 | 11:29 PM
jmrpage's Avatar
hello i am looking for someone who can make custom briaded brakelines for atv's. any info would be great , thanks
Old Oct 7, 2002 | 04:29 AM
modquad's Avatar
Polaris already has the braided stainless lines, and they're cheap too. 2001 and up. You can make tube extensions for extended swingarms, or contact hot seat, they have custom extensions for sale.
Ken
Old Oct 7, 2002 | 11:18 PM
jmrpage's Avatar
well i am looking to redesign the poor performing polaris brakeing system. i need to change some of the fittings . mainly the front line at the master cylinder and i need to shorten and add different fittings on the rear lines . need to make the brakes work like they should not how polaris thought they wanted them to . thanks
Old Oct 7, 2002 | 11:29 PM
PolarisMech's Avatar
you can use the braided lines off a 2001 or new wich will run ya $19 per section.
or you can get a make your own kit from goodridge.
Old Oct 8, 2002 | 12:00 AM
jmrpage's Avatar
do you have a web site address or phone # for goodridge. thanks
Old Oct 8, 2002 | 12:06 AM
http://www.goodridge.net/
make sure you get the right banjo size and bolt thread pitch when ya order.
Old Oct 8, 2002 | 02:54 AM
modquad's Avatar
Sorry if I'm missing something here, but if your machine is a 2002, you already have the best of all the Polaris braking....better master cylinder, steel lines..etc.
Ken
Old Oct 10, 2002 | 12:10 AM
jmrpage's Avatar
Default braided brake lines
yes but the brakes stink. i want to put a front brake lever off from the pred on for the front brakes only . get rid of the left lever . and tie both rear lines together and hook them up to the foot lever. i need to make the brokes work better and like everyone else has them . sick of riding other quads and grabbing a hand full of clutch and nearly getting killed thinking it was the brake lever . very hard habit to break.was also told but never looked for myself that each rear line only controls one half of the caliper. if soo this is really stupid .
Old Oct 10, 2002 | 06:50 PM
talonhawk's Avatar
I've got a 99TB. I changed my brake line around so that the foot lever controls
both lines. Just go to NAPA and get a "T" and take one of the lines with you so
you can get the right size. You will have to disconnect and then plug the line
that comes from the junction up front. You can re-use all that line to run to the
new "T". I left my hand lever alone so I can't help you with that part.
Old Oct 10, 2002 | 10:47 PM
jmrpage's Avatar
talonhawk
how well do you think this helped the brakeing performance of your machine. also does your machine have the braided lines on it . thanks for the info . [img]i/expressions/face-icon-small-happy.gif[/img]
