250 Exhaust
Old Oct 13, 2002 | 01:11 AM
mojave300ex's Avatar
Default 250 Exhaust
I have a fully modded 93 Trailboss 250 and I still have the stock exhaust b/c DG is the only company that makes a pipe for it. In 96 they switched the part number, is that because of a re-designed pipe or a different motor or frame. If the frame and engine are the same won't a pipe for a 02 fit myn. Do you think if I got an HPD pipe for an 02 it would fit my 93?
Old Oct 13, 2002 | 12:32 PM
Bubba297's Avatar
Default 250 Exhaust
If that thing is modded much at all, the stock exhaust is like a cork in the bottle.Check out www.dynoport.com and see if they have a pipe. Thay are the only ones who make a pipe for the 94-95 sport 400L, so it's worth a try. The pipes work good. Hope this helps,Bubba
Old Oct 13, 2002 | 02:02 PM
Default 250 Exhaust
Yeah they do make a pipe for myn. But I would rather stick with a company that specializes in just Polaris, which Dynoport doesn't.
I was kinda asking if a pipe from an 02 will fit my 93. Yes trailblazer/boss have the same frame and engine. However the part number changed in 96 is that because or a re-designed pipe, or a different engine-frame? Because if it's just a different pipe design and the frame and engine are the same why wouldn't a pipe from an 02 fit a 93?
Old Oct 13, 2002 | 06:46 PM
ftwflh's Avatar
Default 250 Exhaust
Try Aaen Performance pipe # PAT20020 price $189 silencer #PAT20021 price$89 Pipe tuned clutch kit #ATC30017 price$20 Hope this helps
Old Oct 14, 2002 | 12:41 AM
Default 250 Exhaust
Has anyone experienced with Aaen pipes? The prices are right.
To simplify my previous questions, does the 02 Trailblazer use a different frame than the 95?
Also has the engine been changed 95-02?
Old Oct 14, 2002 | 07:49 AM
ftwflh's Avatar
Default 250 Exhaust
Aaen is one of the top three pipes you can get for polaris they have been around forever.
Old Oct 16, 2002 | 01:55 PM
BubaHyde's Avatar
Default 250 Exhaust
Yes AAEN has great products and good customer service.
As said before They are probably in the top 3 or 4 for Polaris peformance products. Snowmobole Experts.
RCR performance may also be able to help you out, You will need to call him, No E-Mails.
Old Oct 16, 2002 | 07:03 PM
Default 250 Exhaust
Has anyone heard the AAEN pipe and does it give a nice sound, too loud? My friend had a DG it was obnoxious.
Old Oct 16, 2002 | 07:07 PM
ftwflh's Avatar
Default 250 Exhaust
For info on a DG pipe for trailblazer s check out some old posts in here.They arent the best for a polaris.
Old Oct 16, 2002 | 09:21 PM
Default 250 Exhaust
Did I ask for info on a DG pipe?
