spring spacers
Has anyone used the front spring spacers on there polaris to help wi th plow weight? Do these work to hold the front up? I put on my new warn winch and double tube bumber last night those bolts suck I broke 1 and stretched 3 so I replaced them with grade 8 stainless lawsen bolts. Also does that handel bar rocker switch that you can buy from warn take the electrical load like the one they give you or will it short out being so small?
thanks
thanks
yep them are really kind of tricky getting the winch plate and the bumper on at the same time... had to do it for both of my machines... almost need 2 people to help out with that one....(hard to hold it up and line things up!!) well i dont have spacers and i plow but them spacers help because the 99' magnum at work has them up front and they work good for all the weight we add to the front.... .and they would work good for plowing as well..... well thats about all i know....
Hey Polarisman 3
Thanks for the help!!!! when putting my bumber and winch on I used a Quick Grip that squezzed the plates on the bumber and held it in place with my knee while sticking in bolts.
