spring spacers
Old Oct 15, 2002 | 11:12 AM
TheWayOut's Avatar
Default spring spacers
Has anyone used the front spring spacers on there polaris to help wi th plow weight? Do these work to hold the front up? I put on my new warn winch and double tube bumber last night those bolts suck I broke 1 and stretched 3 so I replaced them with grade 8 stainless lawsen bolts. Also does that handel bar rocker switch that you can buy from warn take the electrical load like the one they give you or will it short out being so small?
thanks
Old Oct 15, 2002 | 12:27 PM
polarisman3's Avatar
yep them are really kind of tricky getting the winch plate and the bumper on at the same time... had to do it for both of my machines... almost need 2 people to help out with that one....(hard to hold it up and line things up!!) well i dont have spacers and i plow but them spacers help because the 99' magnum at work has them up front and they work good for all the weight we add to the front.... .and they would work good for plowing as well..... well thats about all i know....
Old Oct 15, 2002 | 01:28 PM
TheWayOut's Avatar
Hey Polarisman 3
Thanks for the help!!!! when putting my bumber and winch on I used a Quick Grip that squezzed the plates on the bumber and held it in place with my knee while sticking in bolts.
Old Oct 16, 2002 | 04:18 PM
fullthrottle's Avatar
Yep, the spring spacers do help alot , they keep the front end up when the plow is raised. Warn winch and plow on my 2000 xplor 400 4x4.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
