Is there an easy way to remove the gold anodize from wheels?
Old Mar 29, 2000 | 06:28 PM
bash's Avatar
My quad's gold color aluminum wheels just don't look very good in my opinion. It really needs some polished aluminum wheels. In an effort to save some cash for other mods, I thought I might try to remove the gold anodize from the wheels and polish my own.
Have any of you ever tried this and if so, what did you use?
thanks,
Old Mar 29, 2000 | 07:22 PM
Witz's Avatar
I used Easy-Off oven cleaner to remove the anodizing from a set of wheels. I also used a Scotch Brite wheel in a drill to remove the anodizing, after letting the oven cleaner soak for a while and then finished cleaning with steel wool. It's a messy, time consuming process, but cheaper than a new set of rims.
Old Mar 30, 2000 | 02:48 PM
bash's Avatar
Thanks guy.
I started on them this morning but ran out of oven cleaner. They aren't quite quite as shiny as Douglas rims (yet), but look a heck of a lot better than the gold that was on there.
Old Mar 30, 2000 | 04:10 PM
Dill's Avatar
you might find the need to sand the wheels down when you are done, I found when I did mine that the wheels slightly pitted from the steel wool
Old Mar 30, 2000 | 08:30 PM
Witz's Avatar
I found a polish called Simichrome that works quite well for cleaning up tarnished aluminum. It seems to do a little better job of bringing out the shine than Mothers did. It helped put a good shine on my wheels after I stripped the anodizing. Just a suggestion.
Old Mar 30, 2000 | 09:46 PM
cowboy's Avatar
Witz:
Have you tried it on Diamond plate? Or do you think it would work OK for that? I want to clean up a fifth wheel tool box that I mounted on the upper rail of my trailer. Also, where did you find it?
Thanks for the info.
Mike
Old Mar 31, 2000 | 02:35 AM
cw821's Avatar
Find a local anodizing shop. They can take it off in just a couple of min's. It only cost me $5 per wheel, and it takes it all off without a trace. They were left with a smooth but dull look that was easily polished.
good luck....
Old Mar 31, 2000 | 12:12 PM
Witz's Avatar
I've never used it on diamond plate alumnium, but I don't see any reason why it wouldn't work. I picked the Simichrome up at my local shop, and I've also seen it at a couple dealers. It's in a little yellow tube.
Old Mar 31, 2000 | 10:52 PM
Yamaholic's Avatar
most grocery stores have simichrome
and yes it works very well on tread plate
southbayman
Jul 24, 2015 09:30 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Jul 21, 2015 03:03 PM
Desimation2k8
Jul 17, 2015 12:37 AM
