2003 sportsman 700 water pump housing
Old Oct 27, 2002 | 10:12 AM
rbluck's Avatar
Default 2003 sportsman 700 water pump housing
just purchased a new sp700. dealer says it has new water pump cover. from reading the net, i have my doubts. can anyone send a picture of what it looks like. manufactured date 08/15/02
Old Oct 27, 2002 | 06:20 PM
GE4x4's Avatar
I was told that after the maufacturing date of 7/19, the new covers were put on.
Old Oct 27, 2002 | 06:32 PM
Snowride's Avatar
I have not seen a 700 with the reinforcing plate on it yet! They had 2 700's at my local dealer ships and both were build dates 08/27 or 28. He also had 3 600's on the floor, that's where I have seen them. If you look at your cover it is made of a hard type black plastic. The modification is a 3/16" steel plate with the same bolt hole patern, that is simply put over the existing cover to prevent warpage. Look at your cover. Does it have the steel plate?
Old Oct 27, 2002 | 07:16 PM
shopman's Avatar
If the waterpump cover has a steel reinforcement plate, ring that go's over the waterpump cover and the bolts go through it is the new one
Old Oct 27, 2002 | 07:59 PM
mtpockets's Avatar
rBluck,
the old style has a thin rib-edged bracket that holds on the black water pump cover. the new 'kit' has a fat, flat bracket holding it on.
in my area, 700's produced 9/02 on have the new style.
sorry, no pics!
-MT
simple test: rub your hand along the bottom of your water pump.......any wetness? if so, it's a leaker.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
