Best gear set up for lt500?
Old Oct 31, 2002 | 02:54 AM
fast1's Avatar
Default Best gear set up for lt500?
For all around trashing...dirt, trails, drag,dunes, whatever? i'll be running 20x11x9or10 tires. The motor's pretty mild i think (mild port work,little off the head and a paul turner pipe)
thanks in advance, yannick
Old Oct 31, 2002 | 11:32 AM
Duneaddict's Avatar
Many many variables Fast1, I would recommend purchasing a few different sprockets if you can afford it.... I change gearing for each type of riding I do... Different conditions require different gearing for optimum performance. (Rocky MTN. ATV has primary drive sprockets for really cheap)
For the 20" tires, I'd try a 13/40 combo for starters... That's what I run for dirt tires (22") for all around play riding.
For sand and sand drags, I run 13/42 with 12 paddle haulers (22") but I'm probably running a tad bit more ponies than you.
Just experiment to find out what works best for your situation and riding style/conditions. Races can be won/lost with just a little change in gearing.
Hope this helps
Old Oct 31, 2002 | 12:13 PM
OutCast's Avatar
I agree Duneaddict! I use a number of combos for all the differant riding. I run 12/42 for technical rocky stuff, 13/40 on 18x11x10 fast trekkers for trail riding, 13/40 or 13/42 for the dunes on 10 paddle haulers 20x10x10, and 14/40 on the dune drag strip.
Old Nov 20, 2002 | 10:55 PM
truckracer's Avatar
When you run the 14/40 on the drag strip are you leaving the starting line in 1st or 2nd gear? Does that combo pull harder in the bottom or top of the gears?
Old Nov 21, 2002 | 12:48 PM
OutCast's Avatar
I start out in second gear with the 14/40. It pulls extremely hard on the top end, but it has decent torque on the low.
Old Nov 30, 2002 | 11:50 AM
Zilladaddy500's Avatar
14/47 with 400EX rear tire's work's for my Zilla,in the sand I can pull 3rd gear holeshot's without a problem,on hard pack dirt 2nd gear hole shot's,never tried a 40 tooth back sprocket yet,look's like I'm going to call sidewinder and get one...
Old Feb 5, 2003 | 08:56 PM
offroader247's Avatar
I have a stock '90 LT500, still running strong on the original piston. I have the original chain and sprockets and am going to change them. There are some good sprocket combos on here but since I am running stock I want to make sure these will work well for me before I go buy the stuff. What do you guys recommend for dunes, trail, technical, drag for a stocker. I will eventually mod the thing when it finally get's tired but want to know a good combo for now. Also I want to get some better paddles (came with 8 paddle 20X10X10 v sharks) I want to get the 20X10X10 10 paddle haulers. Is this a good setup?
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
