Banshee with oil coming from breather tube?!
Old Apr 1, 2000 | 08:12 AM
Bad_Banshee's Avatar
Here's the deal. Oil from the clutch/transmission is dripping from one of the breather tubes that comes out by the steering stem. I'm I losing a seal somewhere? I have a Chiltons on the Banshee, but nothing in there really helps. Thanks...
BobbyLee
Old Apr 1, 2000 | 10:08 PM
travsbanshee's Avatar
are you sure it isn't leaking from the seal behind your front sprocket, and then running towards the front on your case? that was the problem with mine.
Old Apr 2, 2000 | 12:11 AM
Mike300EX-99's Avatar
Did you over fill it on your last change??
Old Apr 2, 2000 | 08:00 PM
blobby's Avatar
Crank case pressure leaking into gear box, Bad seal on cases.Hence forcing oil up breather. Have had it happen my self.. Strip motor down and re. silicon... Check mateing faces for damage..
Old Apr 4, 2000 | 01:18 AM
350Banshee's Avatar
It does sound like cranckcase pressure is entering your gearbox. The only way this can happen is if you have a right side crank seal that is worn.
Cole Hadden
Jun 15, 2025 09:05 AM
Captjay
Jul 23, 2015 12:33 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
