700 exhaust Problem?
Old Nov 6, 2002 | 03:01 PM
SaintPeter's Avatar
Default 700 exhaust Problem?
My bother and I both have 02 700's and while we were riding last night the exhaust pipes on both machines were glowing red from so much heat. We just got them back from the dealer for there first service. Is this normal or is there something wrong. Any help would be great. Besides this problem we've had no problems.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Nov 6, 2002 | 05:40 PM
Specta's Avatar
An over rich exhaust causes excessive heat in the exhaust. They may need to be jetted with a smaller jet. Also make sure there is not an small leak ahead of the muffler to draw air into the exhaust.
Old Nov 6, 2002 | 05:57 PM
GE4x4's Avatar
It allmost sounds like your running lean, not rich. A lean mix will make the engine run hot. Your either not getting enough fuel or to much air. Check your air box and make sure it's on right, or go up a jet size. You don't want a lean motor, won't last to long.
Old Nov 6, 2002 | 07:17 PM
PolarisMech's Avatar
i'd guess a cracked intake manifold..making it run lean.
very common on early 2002 700's.
Old Nov 8, 2002 | 10:21 AM
SaintPeter's Avatar
Talked to my dealer and they said as long as the temp light stays off its normal.
I going to try another dealer on saturday and see what they say.
thanks for your help
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Mojave250A
Jul 11, 2015 10:38 AM
cSchwartz
Jul 9, 2015 02:43 PM
