Thumb Warmer - Need Advise
Old Nov 9, 2002 | 10:11 AM
NewCatMan's Avatar
Default Thumb Warmer - Need Advise
I'm installing a Parts Unlimited thumb warmer. It has a soft rubber coated warmer. What's the best way to glue this to the throttle? Should I cut off the existing plastic on the throttle? Will glue bond better to the aluminum? I'm considering using super glue and filling the ends with epoxy. I want the cleanest look possible. I don't want to use zip ties around the element.
Any advise is greatly appreciated.
2002 500 Auto
Old Nov 10, 2002 | 08:41 AM
rws's Avatar
rws
I put Hot Grips and a thumbwarmer on my machine. I removed the plastic covering on the throttle, roughed up the surface some and used J & B Weld two part epoxy....has held securely for two years so far.
Old Nov 10, 2002 | 04:07 PM
fivel250rman's Avatar
I use heat shrink about an inch and 3/4 in diameter and about 2" long just slide it over the element and the thumb lever and hit it with a heat gun or hair dryer.Give the wire just enough slack to run the throttle and ziptie the wire to the handlebar.I've used it on at least 40 atv's with no complaints.
donintennessee
Jan 8, 2021 12:40 PM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
Espo720
Aug 19, 2015 02:44 PM
Stever6368
Aug 16, 2015 07:34 PM
Ashley S
Aug 6, 2015 12:56 PM
