who has a cr500 powered atc, i almost do and i have ?'s
Old Nov 17, 2002 | 05:53 PM
200xbasket's Avatar
Default who has a cr500 powered atc, i almost do and i have ?'s
I am bout 3/4 done with mine but i have a few questions.
#1 what kick starter are you using?
#2 what pipe are you using
#3 how long is your swing arm
#4 what gearing are you running
thanks
chris
Old Nov 18, 2002 | 12:03 AM
95wolv's Avatar
I may be wrong,but the cr500 motor may not be a good choice,because of no counterbalancer it will vibrate something fierce in a non-dirtbike frame. Even with rubber mounts to soak it up, you would end up with numb hands and rattling parts after just a short ride. Check with a dealer to be sure about the cr 500 motor, but for sure don't use any motor without a counter balancer to cancle out vibration in the frame.
Old Nov 18, 2002 | 12:26 AM
imported_juggalo's Avatar
trike frames don't create a lot of vibration with a non counterbalanced motor.
Old Nov 21, 2002 | 02:56 AM
KASEY's Avatar
i have a cr500 powered trike with over 500 hrs on it and it hasn't fallen apart!!!!! no broken parts or missing parts either,, kawasaki tecate and the tri z don't have counterbalance shafts!! it vibrates a little ! but its so fast you forget all about it too!! it takes a little more maintainence and up keep to keep her together , one of the hazards of blowing the wheels off every quad on the market today!!!!!!!!!!!!!!!!!!!! yeah!!
Old Nov 25, 2002 | 06:06 AM
200xbasket's Avatar
vibration? what vibration. i rode it today for the 1st time. it is scary fast. check it out here. i go throught the process of building it.
http://www.3wheeler.org/vb/attachmen...=&postid=27496
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
