How do you change the clutch?
Old Nov 20, 2002 | 11:47 PM
mxmike's Avatar
Default How do you change the clutch?
I have never done a clutch job before could some one give me some help or tips before I go and try it?Like if im going to need some special tools or any thing.Thank you.
Old Nov 21, 2002 | 09:02 AM
stocktires's Avatar
On the C-dales, Im guesssing the bottom end is different right?
On my R its a piece of cake! Drain tranny oil and coolant. Take off water pump and side case cover (WP cover and the impeller first!).
Then bam your there, unscrew the 5 bolts that hold the plates down, take them and the springs out and there's ur plates!
Make sure and soak the plates and put them back in the same order (Fiber/steel/fiber/steel/fiber/ I THINK). Oil the lil bearing while yo at it (you'll see it)
And bolt everything back up (make sure and use a torque wrench on the clutch).
Thats my procedure on my 250R, Im sure dales have some differences.
I hope I helped!
Old Nov 21, 2002 | 09:03 AM
stocktires's Avatar
o yeah, No special tools of any kinda on my R
Old Nov 21, 2002 | 09:24 AM
cannondale27's Avatar
Its even easier on a dale than a r.You dont have to drain any oil or coolant just remove the clutch cover on left side your there then follow stock tires directions and before you put cover back on adjust clutch this can be tricky if you dont have the tool for holding the two slotted bearing race you can get by with a snap ring pliers or make a tool. loosen the nut on the allen screw in center of clutch faceplate while holding everything from turning with snapring pliers, back out screw till it is real free no drag, then turn screw in until you feel resistance, backout screw 3 turns tighten nut without moving anything,put cover on your done.
Old Nov 21, 2002 | 07:27 PM
mxmike's Avatar
Thanks guys I think I can handle that.
Njrider1230
Jul 29, 2023 05:16 AM
Cummins Driver
Sep 11, 2019 01:22 PM
merryman
Jan 19, 2016 04:29 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
