650 Rear Spring help
Old Nov 23, 2002 | 01:51 PM
jefffoxsr's Avatar
Default 650 Rear Spring help
I took the spring/shock off the quad to adjust it. The manual says back off the adjuster until the spring is free then tighten it to x depending on your application. Here's the problem. I have adjusted the nut all the way out and the spring still isn't free. What am I doing wrong?
Old Nov 23, 2002 | 09:46 PM
mastrblastr's Avatar
Jeff, you aren't doing anything wrong. There is always going to be positive pressure on the spring. When I took my front struts apart, there was quite a bit of pressure on the spring, even after I took off all the spring retaining hardware. When I took my rear shock out, I backed off my preload adjuster as well, and there was still pressure on the spring. There's nothing wrong with it.
Old Nov 23, 2002 | 09:52 PM
Andy~G's Avatar
Maybe Im missing something,but why take the shock/spring out to adjust it? I did mine while it was on the bike.
Andy G
Old Nov 24, 2002 | 12:19 PM
AndyG, I had to take mine out when I put my liftkit in, so I decided to adjust it while I had it out. Made it a whole lot easier to do!!
Old Nov 24, 2002 | 01:28 PM
Andy~G's Avatar
Gottcha.
Andy
Old Nov 24, 2002 | 08:59 PM
alltoys's Avatar
Mastrblastr
That's some serious air underneath your red rocket. Your wish to Santy Clause apart from a CDI will be nice BIG RED WINGS LOL! I can see the headlines now BIG RED KAWI 650 WITH MAGICAL RED WINGS PULLS SANTY'S SLEIGH AROUND THE WORLD IN RECORD TIME. OLOL!!!!!
Old Nov 25, 2002 | 02:45 AM
Alltoys, I don't fly my 650 too often. Too much weight in the saddle makes for some serious abuse of my red toy! You shoulda seen the air my buddy was getting on his Grizzly!!!!!!! Just sick!!
Old Nov 25, 2002 | 10:00 PM
kawlaris's Avatar
You do not need to remove the rear shock to adjust it. If you get the top locking nut loose by using a long bar and hammer it is easy. I spray the top shock threads and also the bottom of the spring with WD-40. Then you can easily turn the spring by hand and it will turn the top adjuster nut. You can also make it easier by taking the weight off the rear spring by supporting the quad or have some one lift up on the rear.
merryman
Jan 19, 2016 04:29 AM
brinkkl2000
Oct 16, 2015 11:08 AM
Polaris5
Aug 29, 2015 09:11 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
