outlanders
Old Nov 23, 2002 | 04:18 PM
pulsar's Avatar
Default outlanders
what does everyone think of the three new bombardier outlanders?
It seems kind of dumb to just put a smaller piston or something like that and not lighten it up abit.
I think they should have not used the independint suspension on the two wheel drive models.
check them all out on the bombardier website.
Old Nov 23, 2002 | 09:22 PM
RINCON's Avatar
Default outlanders
i believe they are very good performers.
What's wrong with IRS on 2WD's?
Old Nov 24, 2002 | 02:48 PM
pulsar's Avatar
Default outlanders
well it adds lots of weight the 2x4 weighs 550 lbs. adds body roll. but you get ground clearence but my thinking is that in a two wheel drive the only thing it is good for is going over loggs and rocks. I dont think it would help that much in the mud unless you have enough speed.
Old Nov 25, 2002 | 05:44 PM
RINCON's Avatar
Default outlanders
adds body roll
The outlander has a different IRS set-up. The wheels travel straight up and down, not like an A-arm equiped SP500 or grizz660.
The main thing IRS does is gives a magic carpet ride.
Old Nov 28, 2002 | 12:34 PM
pulsar's Avatar
Default outlanders
It shouldn't make a differnce. If one side has the ability to move without the other getting off the ground it will lean into the turns. trucks with semi independent (solid axle) rear get boat like in the turns the only thing that would help would be stiff suspension , sway bar or a standard rear straight axle only able to move both tires up and down at the same time.
Old Nov 28, 2002 | 04:10 PM
RINCON's Avatar
Default outlanders
it has a sway bar.
I'd put up with a little roll for the ride IRS gives.
bigred20653
Oct 2, 2015 10:05 AM
panicmanic
Sep 28, 2015 12:59 PM
bigred20653
Sep 19, 2015 02:11 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Gtsordo
Jul 22, 2015 01:27 PM
