14/42=3.00 ratio...good setup for LT250R?
Old Nov 29, 2002 | 09:21 PM
DCopp's Avatar
Default 14/42=3.00 ratio...good setup for LT250R?
fourteen front with an aluminum 42 rear...results in a 3.00 gear ratio...i figure this is good for all purpose riding...am I right?
Old Nov 29, 2002 | 09:26 PM
1986SuZuKiQuAdRaCeR's Avatar
last time i checked that was the stock gearing.
Old Nov 30, 2002 | 01:56 AM
lt250r91's Avatar
12/42 is the stock sprocket sizes.
What size rear tires?
I ran 11/41 with 22" tires for woods racing.
14/42 will give you more top speed, but you will lose accelleration. I would reccomend 11/41 with 22" tires or 12/40 with 20" tires. These will give you more top end speed with out losing as much bottom end.
Old Nov 30, 2002 | 10:50 AM
badchad's Avatar
Gearing also depends on what type of riding you do, and what mods you may have. I normally run a 13/42 with 18" tires, but depending on what track, trail, etc you're riding will really be the determining factor. Also, a motor that is modded will be able to pull higher gearing. Remember, 1 tooth up on the countershaft sprocket normally equals to 2 teeth down on the rear sprocket.
Old Nov 30, 2002 | 02:54 PM
mrbones's Avatar
I run 11/42 with 22" All Traks on the rear. I ride woods trails, small sand tracks, some small hill climbing (all in the sand, I'm in FL BTW). I never see 6th gear, and rarely see 5th or even 4th just because there isn't enough open area where I ride. Most of the time I'm in 2nd and 3rd gear. I've only had up to 50 MPH in 5th until I ran out of road. For me, the gearing suits my general purpose riding. I think you can put in a 11, 12, or 13 front sprocket without changing the chain length. I didn't need to when I put on my 11 tooth. Just had to adjust the chain tension. So get a couple of sprockets and experiment to see which is best for you.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Levi Enstad
Sep 26, 2015 08:00 AM
jbrewster94
Sep 23, 2015 04:16 PM
Halffast17
Sep 11, 2015 02:30 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
