needle clip
Old Dec 3, 2002 | 04:01 AM
cOoLdevil's Avatar
Default needle clip
hi i like to know what is the difrance in the posetion of the needle clip #2 #3 #4 in drag racing and for top speed
Old Dec 3, 2002 | 10:27 AM
Eaglecollector's Avatar
Default needle clip
From what i understand. The needle clip pos will determine how far the needle sets into the main jet at idle and on WOT. You would get more fuel mixing with the air the farther the needle is out of the main jet. To much fuel is to rich and not enough is to lean. Some place in between is making HP. This clip poss. you have to play with and test, test, test.
Old Dec 3, 2002 | 11:45 AM
KenDS's Avatar
Default needle clip
The clip position of the needle determines the fuel mixture in the transition circuit, in other words "midrange" throttle. It has little or no effect on idle or WOT. It effects 1/8 to 3/4 throttle. If your midrange acceleration is crisp and strong, leave it alone.
Old Dec 3, 2002 | 02:43 PM
Default needle clip
Well there ya go.......glad I don't have to mess with that any more. But when I did mine was in the 3rd from the top and a 190 main. K&N in the box.
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 2, 2015 11:15 PM
