Cylinder Head Removal
Old Dec 6, 2002 | 06:08 PM
Eaglecollector's Avatar
Default Cylinder Head Removal
I was looking at my shop manual for the procedure I will have to go through when I can afford to get a high comp. piston. Well, it says that i'll have to remove the engine from the quad to get the head and cylinder off. Is that true? Isn't there enough room to swap out pistons without remove the engine?
Old Dec 6, 2002 | 06:17 PM
Kodiak01's Avatar
U should be able to do the swap without complete removal. Just remove the intake manifold, front motor mounts, & lower motor mounts then tilt the motor forward. You should have enough room to do it.
Old Dec 6, 2002 | 06:37 PM
Thats good to hear. I see you have a 11.5:1 piston. Did you install it?
Old Dec 6, 2002 | 08:23 PM
KenDS's Avatar
If you notch the frame just above the rear head motor mount, like RWR does, the head will slide off of the studs with no problem. No worries, plenty of frame strength in that area.
Old Dec 6, 2002 | 09:24 PM
FastYellow650's Avatar
do you have a pic of how the notch is cut, i too will be installing a new piston soon i hope a 12.5 : 1 from tvi
Old Dec 7, 2002 | 12:50 AM
ThePunisher's Avatar
Just tilt the motor forward. It is really easy. Undo all the motor mounts except for the lower back one and it will tilt forward just enough.
Old Dec 9, 2002 | 12:27 PM
KenDS's Avatar
No on the picture. I don't have a digital camera. But it is real obvious when you get to that point, you just pull the head up the studs until it contacts the frame and you will see the little bit that needs to be removed. It takes a little time the first time, but reassembly goes very smooth, and if you remove the head again, for valve work, or say a 12.5:1 piston, you will be glad that you did it this way.
Old Dec 9, 2002 | 08:52 PM
SANDMAN430's Avatar
there is plenty of room, like they said just pull the intake manifold and the front engine mount. no cutting required. just replace the head nuts when reinstalling.
Old Dec 23, 2002 | 12:20 AM
wshrdskin's Avatar
Hmm, sneaky sumbiatch. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 23, 2002 | 01:36 AM
Damn Larry your just ot to get me aren't you!!! LOL[img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img] Are you going to be out at Dumont this weekend?
