Largest tire without problems
Old Dec 8, 2002 | 12:44 AM
abennett's Avatar
Default Largest tire without problems
What is the largest tire that I can install on my 2001 500 HO without having to worry about breaking or ripping my plastics off. And without having clearance problems.
Thanks
Old Dec 8, 2002 | 01:02 AM
mtpockets's Avatar
i had 26" Outlaws on my SP500. fronts were 10". rears were 12" wide.
rears no problem.
fronts were terrible. they rubbed bad on turns with the stock shocks even with 2 sets of Polaris rubber spacers.
i think the TREAD had a lot to do with it. you see, with the Outlaws the tread wraps-around the sidewall of the tire for better gripping in deep mud. and that's where things get skrewed-up. other tires don't have that side-wall tread so i think some 10" wide front tires would work just fine.
i think you have to list what tires you are concidering going with to get accurate feedback.
Old Dec 8, 2002 | 01:30 AM
MinnesotaRIPPER's Avatar
The biggest you can go is a 26". In front the widest you can go is a is a 9 or 9.5 and 10" wide vamps will work too because they really measure 9.5" wide. Any wider and you will rub the shocks.
Old Dec 8, 2002 | 11:43 AM
Mike Chero's Avatar
Here is a free tip to someone who wants to put wider front tires on their Sportsman. Use wheel spacers from a Yamaha Banshee. They have the exact same 4/156 bolt pattern as Polaris does. I believe Durablue makes them.
Old Dec 8, 2002 | 07:29 PM
500DUSE's Avatar
I dont have a problem with the ITP 589's
10's and 12's
If you hit the whoops just right the tire would rub the fender,
Old Dec 8, 2002 | 07:57 PM
Yeah if you want to put wider tires on front you can put on spacers. Wide Tracs made by Highlifter are by far the best. I have the 1.5" Highlifter also makes 1" wide. Plus spacers also give you more bit in the ruts.
Old Dec 9, 2002 | 12:11 AM
Traildog's Avatar
I'm sure 26" tire will do fine for "normal" riding but I have had my rear tires rub the plastic on landing from a jump and they are stock 25" Tracker Ps.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
