2000 trailblazer drowned now won't start
Old Dec 8, 2002 | 06:09 PM
MuddyWater's Avatar
Default 2000 trailblazer drowned now won't start
I was out trail riding found a water hole that happened to have a deeper hole in the center. Not knowing this I inadvertantly drowned my machine. I was able to drain it and got it fired up and running in the field, drove it straight to the trailer to load up. I shut it down when I got there, went to start it back up, but nothing. It will turn over and has good spark, but will not fire. Since that day I have made sure everything is drained, pulled the carb. apart cleaned it, put everthing back together but still will not fire. It is getting fuel, cause I can keep cranking it, and eventually I will flood it. It did try to start twice, I was holding throttle wide open and keep cranking it, then it will try to start but will not go.
Can anyone PLEASE!! help me out here what should I be looking for. Any advice greatly appreciated.
Yes I know what some of you will say(stay out of deep water,Its not a submarine)LOL
Thak you in advance
Hank
Old Dec 8, 2002 | 06:36 PM
ftwflh's Avatar
Did you set it up on the rear end and drain the water out of the pipe?And blow both jets out to be sure there was no water or crud in them.Did you turn the motor over with the plug out of it to blow the water out of the cylinder.Hope you get it running.
green giant
Jul 13, 2017 12:07 PM
mpcop077
Jun 10, 2015 08:30 PM
wbfjim
Jun 8, 2015 06:20 PM
1000gade
May 27, 2015 12:37 PM
