Grizzly rear drum brake drag
Old Apr 5, 2000 | 11:32 PM
BigDogs's Avatar
My grizzly rear drum brake provides a enormous amount of drag even when not applied but when i go around to the back by the rear axle and i manually pull back on the arm to which all the cables are attached to there is hardly any drag.
Also when riding the drum gets extremely hot from the friction. I was wonder if anyone else had this problem and if there is an easy way to fix it?
Old Apr 6, 2000 | 12:15 AM
t1602's Avatar
If you take apart the brakes, you will most likely find that the brake pads have broken loose from the brake shoe. Don't ride till you see if this is the case because you will distroy your brake drum (very expensive) BUY AFTER MARKET BRAKES. YAMAHAS BRAKES ARE THE WORST YOU CAN BUY,THIS HAPPENS ALL THE TIME!
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
