blaster oil injection
Old Apr 6, 2000 | 04:40 PM
98'200blaster's Avatar
has any body taken off their oil injection on their blaster and had any problems with it
Old Apr 6, 2000 | 11:18 PM
THEXOTIC1's Avatar
i owned a 91 blaster and the oil pump failed and the crank and pistion bearings both went. You do not have to buy the block off kit just get a left side gasket take the cover off and take the white plastic gear off the back of the pump disconnet and remove the lines and also remove the oil box and bracket you can take the wire that went to the oil light and put them tigether to have the red light on all the time or just leave undone also remove the oil line from the carb and remember to put something to block dirt from entering the carb i used a little red rubber cap from a can of oil it worked and never came off. Also premix the gas as 32/1 and you will never have the same problem i have had good luck
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
