Questions for those that have or had realtors?
Old Dec 19, 2002 | 11:40 PM
MudStud's Avatar
Default Questions for those that have or had realtors?
How does tread hold up?
How does DS react with them on it?
Does it Accelerat faster?
How does it handle on top end?
Does it still slid the back when you want?
Can you beat a stock DS with stock tires since you dont slip as much?
Can you run them in PADDLE mode always?
Sorry about the poop. I cant afford to try all tire types.. Thanks!
Old Dec 20, 2002 | 12:13 AM
FasterThenYou's Avatar
How does tread hold up? They wore really fast on me
How does DS react with them on it? They pretty good they make your quad a little more bumpy casue ur riding on hard ground with paddles....they also will make your bearings go prematurely
Does it Accelerat faster? Compared to stock yes but since you have 4 inchs of space between each tread they will spin a lot on like grass
How does it handle on top end? They handle fine but when on pavement or hard ground it feels wierd
Does it still slid the back when you want? Ya they will slide when you want them to but not as good as holeshots
Can you beat a stock DS with stock tires since you dont slip as much? Ya there is no question of it
Can you run them in PADDLE mode always? Ya
Pure sport also makes a tire called the Bandit(sp??) I heard them to be good.....They used them when they won the baja 2000..Just my .02 cents
Old Dec 20, 2002 | 12:41 AM
MudStud's Avatar
Thanks for that GOOD review!!!
Would you stay with HS or back to a Non nobie tire?
Old Dec 20, 2002 | 09:17 AM
bombthreat187's Avatar
How does tread hold up. great . i have had mine on for over a year and they still have 70 % life left
How does DS react with them on it? it lets u put all that hp to the ground with no problem .
Does it Accelerat faster?yes just because your hooking up better
How does it handle on top end?i just cam to find out .because realtors are 22in it throws off the gearing a bit .the bike won't rev out as fast in higher gears
Does it still slid the back when you want?i have had no problem with sliding it .at all
Can you beat a stock DS with stock tires since you dont slip as much? yes
Can you run them in PADDLE mode always? i always do .thats the only way i run them
Old Dec 20, 2002 | 10:13 AM
mojavekid13's Avatar
Pure sport bandits! they are a VERY VERY good tire! I nwo have razrs on just because iam doing smoe MX but if i was trail riding again! I dont knwo its hard to choose! bouth are very good! razr and bandits
Old Dec 20, 2002 | 05:14 PM
JEFFROE's Avatar
i've run the realator's in the snow mostly, good in the mud, but for all around trail riding? we both live in wisconsin, there are alot of logging roads to run on, best bet for faster riding would be a knobby (hole shots,razors ect) but mount up a set and keep around for when you need more traction in the mud or snow!! i bought a set of used rims from my dealer for $25 and keep my realators handy for the soft stuff. p.s. they suck in the dunes
Old Dec 20, 2002 | 05:17 PM
918sTaxi's Avatar
I had a realtor when I sold my first house. IMO she wasn't very good, seems like I did more work then she did. And she took a s!@# load of my profit.[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 20, 2002 | 07:10 PM
lilnotts's Avatar
How does tread hold up?pretty good, but if its very dry and you do road riding you will notice wear
How does DS react with them on it?it likes them, doesn't spin as much
Does it Accelerat faster?prolly not since they are taller, but only by 1"
How does it handle on top end?i never drove a bonestock ds, but not much different comparing to excavator
Does it still slid the back when you want?o ya, easily
Can you beat a stock DS with stock tires since you dont slip as much?most likely, there is not many ds's around here so i can't compare,
Can you run them in PADDLE mode always?yes u can
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
