A DAY AT THE 1/8TH MILE
Old Dec 23, 2002 | 02:25 AM
QUADMAN650's Avatar
Default A DAY AT THE 1/8TH MILE
Well to get started i get there about 1:00 PM unload the bike get it running 1:30 i attempt to make my first pass i line up with the ds struted in the front only do a small burnout and pull to the line i take off in 1st and the tires unload through the first 2 gears. I couldn't get any traction what so ever i end up running a 9.40 at 69 mph With my second pass i go around the water do a small burnout and lime up against a raptor . Only this time i take off in second what do you know the tires break loose i start white smoking and i start going sideways DAMN i had to let off and let the raptor beat me. So i went to the pits and decide that the front struts have taken all the weight from the back end and transfered it all to the front thus causing me to spin off the line. So i took the struts off and put my shocks on and went from a 14 tooth sprocket to a 16 tooth. 3.00 Pm rolls around i attempt to make my 3rd pass me and the raptor line up again i watch the yellow lights come down 3rd ligh appears i'm on the wood raptor ends up runnin a 9.30 at 70mph and i end uo with and 8.95 and 71.5 mph. ONCE AGAIN DS650 DEFEATS RAPTOR.
I don't think my 4-wheeler ran its best today but It was my first time at the 1/8th mile if anyone has raced on it before tell me your times so I can compare and what you setup may have been
Old Dec 23, 2002 | 12:10 PM
dsmike's Avatar
your times are pretty good.
on my yellow bike with a stock pipe, cams and piston i ran a 8.60. i'm not for sure about the MPH. i just use that bike to play around on at the track. it fun making them spin about 60' then wheelie the next 100yards.
i will try and get down there when alot of you texans race the 1/8 mile again.
Old Dec 23, 2002 | 12:55 PM
biggerisbetter's Avatar
Brandon good times.
My first time was a 9.1(I think), but I was able to get a 8.80 74 mph the second time I went to the Track. That asphault drag races is FUN isn't it!
I cant believe you let a RAPPY beat you!!!![img]i/expressions/face-icon-small-mad.gif[/img] UNACCEPTABLE...[img]i/expressions/face-icon-small-wink.gif[/img]
BIggerisbetter.
Old Dec 23, 2002 | 01:26 PM
SAMCOEDS's Avatar
I WANT TO GO we all should get together and try to go to the same track sometime itlll be a blast.
Old Dec 23, 2002 | 01:38 PM
I'm IN!!!!!!!!!!!!!!!!!!!!! [img]i/expressions/face-icon-small-happy.gif[/img]
Biggerisbetter.
Old Dec 23, 2002 | 02:03 PM
QUADMAN650's Avatar
I believe the track that dsmike goes would be pretty neutral but dsmike are they open?
The track i went to is open all winter as long as the temp is above 50 degrees and its not raining
Old Dec 23, 2002 | 03:08 PM
dsmike's Avatar
No the track is closed for the year. they will not open back up til march.
we will have to come to your track.
i will come
Samcoe load up and go to Glamis with us.
Old Dec 23, 2002 | 05:21 PM
SAMCOEDS's Avatar
DS MIKE i an out of vacation till after the first of the year or i would go.
Old Dec 23, 2002 | 05:28 PM
vilnrk's Avatar
I would like to go to the 1/8 to see what my predator 500 can do. It feels faster than my raptor.
Old Dec 23, 2002 | 05:30 PM
SAMCOEDS's Avatar
mine does to oh yea i dont have one hahahaha.
