Traxter plug fouling
Old Dec 31, 2002 | 10:36 AM
BT's Avatar
BT
Default Traxter plug fouling
Hi All ,
I have an 01 XT that i bought new . It has a bad habit of fouling plugs . Have to be careful on start/warm-up . It always seems hard to start when cold and seems to take a while to get warmed up . I'm thinking it needs some jetting changes ?
Anyone aware of bulletins/updates ?
Thanx
Old Jan 2, 2003 | 01:15 PM
CanadianViking's Avatar
It sounds like you might be running a little lean - as you indicated it probably is a jetting issue. Did you dealer re-jet it for your altitude?
Also, the Traxter is a little cold hearted to begin with and cold starting can be an issue - especially if not jetted correctly.
If you are going to replace your plug, I've heard from many Traxter owners that see some better performance with some after market plugs. I can't recall the specification right now, but if you are interested let me know and I'll get the information.
Cheers,
Old Jan 3, 2003 | 07:46 AM
BT's Avatar
BT
Viking ,
Thanks for the reply .
I've talked to a couple different dealers but reply with no known problems . My lovely wife tucked the owners manual away , yet to be found . I'm not sure that would cover carb settings . I decided to take a look at the carb and discovered maybe the only flaw in the Traxter design . The fuel screw . Why it's positioned in an impossible spot to access is a major bummer . Maybe a specialty right angle screwdriver would help , but you still can't see the D##n thing ! I started to pull the carb and found that's not a 'quickaminute' job either.
I'll give it another go this weekend , but would be nice to get some baseline to start .
I'm also thinking about changing/drilling out the choke jet if possible . I've done this on a couple dirt bikes with good results .
Later
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Bkeb
Aug 12, 2015 12:45 PM
cornermike
Jul 30, 2015 06:37 AM
tporath
Jul 11, 2015 12:31 PM
