HELP me lower polaris shocks
well guys once agian i need some help so,i was wonderin how i could be able to lower my shocks or were i could get a set that would lower it causei plan on givin my scrappy a race readuy look and sittin high aint speedy lookin, hook a brother up wit a couple good ideas.
OK, there is only so low you can go with it. Here's what you do. Contact your polaris parts person and order some springs. If you order the firm springs for front and back it will lower the bike about an inch all around ans you wont lose any ride. The front spring # is 7041375-067. The rear spring # is 7041303-067.The front you have now is a straight rate spring, and the replacement is a dual rate. As the spring travels it gets stiffer. It wont bottom out near as easy. These will actually fit the 99 and up sport and scramblers. It did make quite a handling difference on my bike.Hope this helps,Bubba
