AC NERF BARS BETWEEN THE FRAME
Old Jan 1, 2003 | 03:07 PM
Milkweed's Avatar
Default AC NERF BARS BETWEEN THE FRAME
Hey Everybody,
I was just noticing that my ac nerf bars between the frame the little tube that fits in the other nerf big tube does not slide in all the way. In fact they only slide into each other maybe a half of an inch. Is that how it is supposed to be? Or should they be all the way inside of each other. Hope that makes sense.
Thanks for the help in advance.
Old Jan 1, 2003 | 04:21 PM
prang11's Avatar
Do they fit on your quad right? Are they bowed out in the front? If you dont like it why dont u take them apart and san the inside out a little. I have DG nerfs and they fit inside each other as far as you will push them. Just check them out. If you want them to go together more make them. Good luck
Old Jan 1, 2003 | 07:33 PM
dariusld's Avatar
Don't listen to prang11. That is how they are supposed to fit. That is how mine fit and everyone I know fit the same way.
Old Jan 1, 2003 | 09:53 PM
Milkweed's Avatar
Thank you dariusld & prang11! I screwed with them some and they fit great now!!! Thanks!!
Valder
Nov 28, 2020 07:38 AM
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
EIF
Apr 20, 2017 07:15 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
