Oil Pressure gauge
Old Jan 5, 2003 | 01:34 PM
MadBaja819's Avatar
Default Oil Pressure gauge
Ok, I mounted my pressure gauge up everything, and I installed the sensor with a 3/8 tee with a 1/8 sensor fitting in the oil return line. My question is why am I reading no pressure, I have clear line and the oil slowly works its way up to the gauge, but the gauge will read. My question is the oil return line really under the little of pressure? Also where have you put the sensor for your gaughes.
Old Jan 5, 2003 | 01:39 PM
BillDS650's Avatar
You should have mounted it at the oil sending unite not the return line. The return line is gravity feed I think that is why the oil tank can not be relocated.
Old Jan 5, 2003 | 02:38 PM
MadBaja819's Avatar
Ok, well it is no big deal, I can remount it. Where is the oil sending unit, is that the plug on top of where the oil filter is located.
Old Jan 5, 2003 | 02:49 PM
BillDS650's Avatar
That is the one. In the manual it is called the oil pressure switch and is where you check the engine oil pressure. Minimum 7 PSI at ideal, 44 PSI at 6600 RPM and max of 87 PSI
Old Jan 6, 2003 | 09:15 AM
02BAJA's Avatar
The sending unit is on top of the case, behind the cylinder. Right under the carb. Its about 1.5-2" long. Cant miss it.
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Logan Collins
Sep 5, 2015 08:03 PM
