questions about RWR tm45 carb
I have a hmf slip on, K&N air filter, dyno jet kit, RWR cdi box, and twist throttle. I want to install a TM 45 carb, and their ported intake manifold. Will the 45 carb fit into the stock air box, and what jets should i use? Will the dyno jet kit jets work in that carb? any other info would be helpfull, thanx.
You can run the stock airbox you just have to stretch the boot over the carb. And no you can't use any of the Dynojet stuff with that carb. You are pretty close to sea level there, and the stock carbureation that comes with that carb is perfect from sea level to 3000 ft. Don't change a thing.
