Bigger carbs on my shee?
Old Jan 6, 2003 | 06:32 PM
RIDEORDIEYZF's Avatar
Default Bigger carbs on my shee?
What size carbs do you guys run on your shees? I've heard if i got bigger carbs(35mm i think) that it would be way faster. But what type of fast?(low end, topend?) I also have the tommey perfect jetkit, would i have to change that?
Thanks for the info
Old Jan 6, 2003 | 06:42 PM
Ernie660R's Avatar
It depends on how much port work has been done on your shee. If you do not have the port work the engine will not be able to pull the cfm through the larger carbs. Terrible low end and take forever to get to top end, Ifyou have mild port matched 28mm to 30mm carbs would work well. All out port and CPI drag piped 34mm to 38mm carbs. The choice is yours.
Also if you are running small cc domes like 18cc this would help if you are dead set on getting larger carbs.
Old Jan 6, 2003 | 06:51 PM
would port work make it unreliable? It runs great now and i wouldn't wanna tomess with a good thing.
Old Jan 6, 2003 | 10:36 PM
Ernie660R's Avatar
I also have a J-Arm 1989 Banshee, I did all the port work on mine and I run 34mm Keihin PJ Carbs with 18cc cool domes. If your banshee is already running great with no problems I would leave it alone.
Have you tried advancing your timing 4 degrees that will give you a little more umpf, or even try a little more ignition power for more spark.
Port work will not effect reliablity on your banshee, just performance. but always remember you must jet up when you do any port work.
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
