Throttle slow responding
Old Jan 11, 2003 | 08:30 PM
bigtom0029's Avatar
Default Throttle slow responding
I have a scrambler 400 4x4 2 stroke and when I give it throttle it doesn't respond very quickly, I have to hold it wide open to get it going and it will slowing get to full throttle. but when I let off it starts all over. I will not idle either. anyone got any ideas?
Old Jan 11, 2003 | 10:26 PM
Mudracer300's Avatar
sonds like something in the carb just try taking it off and cleaning it and the intake stuff too like the filter. hope this helps probably someone else will know more though
Old Jan 11, 2003 | 11:37 PM
Firehawk1970's Avatar
Make sure cable is adjusted correctly at entrance of throttle assemby on handle bars...mine is under a rubber type slipaway cover...
Old Jan 12, 2003 | 09:52 AM
bigtom0029's Avatar
I will check it out, If ya'll think of anything else please let me know.
Old Jan 12, 2003 | 10:34 AM
ftwflh's Avatar
Check your compresion it should be over 100lbs if nt it wont idle or run right.
Old Jan 12, 2003 | 05:34 PM
Quadfather's Avatar
Check the air filter to make sure it is clean. You also might want to inspect the reed petals.
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Brandon400
Sep 7, 2015 12:20 PM
black_thunder
Sep 6, 2015 04:41 PM
