engine torque plate
Old Jan 13, 2003 | 09:03 AM
POLARISFREAK's Avatar
Default engine torque plate
Anyone out there running an engine torque plate on there high hp sport/scrambler. Looking for input on the product and where you purchased it.
Old Jan 13, 2003 | 09:37 AM
Bubba297's Avatar
Got mine from Dennis Shotwell (ddjshotwell@qwest.net). Cost me about $50, but the earlier model like yours isn't that much. Sure keeps the engine from trying to twist around. Did you get the pics last night? Bubba
Old Jan 13, 2003 | 09:40 AM
Yeah, Bubba I got them thank you very much. I guess the bar does a good job of holding you down. How far off the ground did you set the wheels on the wheelie bar. Also do you think the small wheels will do ok on sand? I'm still looking into alky, I think I will see what my times are as is and then decide what to do on alky. I'm keeping my eyes open for used cars. I hope to run a low 5 as it sits, do you think this is realistic?
Old Jan 13, 2003 | 10:10 AM
Bubba297's Avatar
Yes, low 5's should be realistic. I ran 5.2's on 300ft dirt on turf tamer tires. I also weigh in right at 200lbs. If I was going to run sand with those bars, I would either put a bigger wider wheel, or a slider plate. I have seen guys running a slider setup with extended swingarms. It shouldnt try to come up too bad on you, and you only need the bars for the first 60ft or less usually. Keep the bars just far enough off the ground to give just a little movement of the bike front end and help transfer some weight to the back.
Old Jan 13, 2003 | 10:19 AM
Thanks for the info. you have been very helpfull. I'm going to order the torque plate and get to work on a wheelie bar. I'll let you know what I run and what I decide to do about alky. Thanks for all the info. I'm glad I found this forum.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
95wolv
Jul 21, 2015 12:25 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
