2000 rancher ES 4x4 electrical problem
Old Jan 20, 2003 | 01:02 PM
unoki's Avatar
Default 2000 rancher ES 4x4 electrical problem
went out today to plow some snow !!
seems it will try starting on it's own, sprayed contact cleaner on starter button and no help
any ideas ?? possible icm , bad swicth, or starter relay[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 20, 2003 | 03:15 PM
Totschb's Avatar
The machine will not start in gear unless you have changed something so IF it want's to start on it's own in neutral than go to the cheepest thing to change out and I would guess that would be the starter button. By the way have you thought about asking a Honda Mechanic about this problem? Sometimes they are of great help.
Old Jan 21, 2003 | 04:31 AM
swampdonkeykiller's Avatar
sounds to me like your starter solenoid/relay is shorting out and causing your starter to engage. Your starter button doesn't get power to it when in gear so it most likely isn't that---unless it tries to start itself when it is running and in neutral only, then it may be the starter button but still unlikely.
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
ranvette
Jul 4, 2015 06:13 PM
Mikea1978
Jul 4, 2015 12:37 PM
