my rear wheels on my blaster do not spin
i went out to ride my blaster and the rear wheels are locked on. Its in neutral and wont spin. i even put i on a jack and tried spinning them but they wouldnt move. I even tried pullin in the clutch and the still wouldnt move. If u now anything and can help please reply.
If the parking brake is not on, and the brakes are not frozen/locked....Then it sounds like you burnt some bearings.
Check the rear disk and see if the brakes are rubbing it.... If they are clear, you will have to get the axel off.
Pop the clip on the chain and take it off, if it still wont spin then the problem isn't in your brakes. Then take the plug out and see if it will kic k over with no compression to hold it back, if it dosen't like they said you might have seized the bearings. Good luck!!
The parking break is not on and it will kick over. I dont know if it will start because the key wasnt in it. One of my freins said on the shifter shaft that goes in the engine theres forks on it and they might have slipped off. Is that possible. please right back
i started it up and it ran. You guys taht think the bearings are gone how would taht happen because last time i rode it it ran and worked fine. It sat in my garage a week then i went to move it and it wouldnt roll. write back
you wouldnt believe how hot they get sometime.
I put black water tires on my 300ex before and i was going down the road and was slowing down for some reason.
I stopped looked at the bearings and the grease was so hot it was bubbling out
when you have the chain off does the axle spin ??
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
