Pred suspension
Old Jan 21, 2003 | 08:43 PM
MFGrizzly660's Avatar
Default Pred suspension
Do any of you weigh around 135 lbs and have a good suspension setup? just wonderin, stock is way too stiff and havent played around with it yet. Well any help would be great. Thanks in advance.
Old Jan 21, 2003 | 09:57 PM
GE4x4's Avatar
Well I weigh about 50+ lbs more then you, and I thought the suspension was stiff, it must be real bad on you. Well this is what I did. Put the front up so the front wheels are off the ground. I turned the pre-load until there was no tension on the collar. The front feels very good now. You might have to go higher. The rear is a little more work. First I put the preload up to about 1 1/2" to the top. Set the compresion to 1 and put the rebound at 20 clicks. Right now I'm very happy with this set-up.
Robinhood
Dec 26, 2015 10:28 AM
BYC
Sep 25, 2015 02:10 PM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
