How to fix a flat tire?
Old Jan 22, 2003 | 02:10 PM
RotaryRocket's Avatar
Default How to fix a flat tire?
I got a nail in my front Titan 489 (#?) tire. When I pull the nail out I can hear air escaping.
Do I use a "radial tire" repair kit (with the hole reamer, and the sticky strips to be pushed in the hole) for this puncture?
Old Jan 22, 2003 | 07:09 PM
DaveB's Avatar
You need one that is specifically for low pressure quad tires....the automotive ones are too stiff and pull out with the tool damn near every time. (yes....I learned the hard way LOL)
Old Jan 22, 2003 | 07:59 PM
Thanks Dave. So do you think a motorcycle shop would carry a "low pressure" repair kit?
Does anyone sell it on line?
Old Jan 22, 2003 | 08:18 PM
mountainclimber's Avatar
High lifter may carry them. Or you can try slime tire sealent.
Old Jan 23, 2003 | 08:25 AM
upnort's Avatar
I used the same plugs in my atv tires as my truck because basicly that is what I had. I have had them pull out while installing but practice and being careful cured that. These plugs lasted 2-3 years until I traded it in. I had at least a total of 6 in both front and rear. These are the like 6 inch rope looking ones. Also used the rubber ones. I have never tried slime.
Old Jan 23, 2003 | 09:52 AM
warrior007's Avatar
The key is twisting the plug inside the whole to knot it up, grab it at the base after insertion and give her a twist and a yank. It should stay in - and use the glue, it helps to lube things up.
(kinda sounds naughty!! )
Cleck out my tire in my pictures, it has 18 plugs in it. (10 happened that one day, I changed the tire once I got home but had no [problem riding the rest of the day)
Old Jan 23, 2003 | 11:22 AM
Thank you all for the great insite.
Warrior, LOL at your tire. Man that thing looks like it could use a "hair cut"....
2quiker
Mar 22, 2022 08:36 PM
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
caveeagle
Sep 19, 2015 01:20 PM
essonlaker
Sep 10, 2015 01:12 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
