Shocks and A-arms
Old Apr 11, 2000 | 01:28 PM
Banshee28's Avatar
I am going to buy a set of shocks for my Banshee, should I get TCS or Works shocks? I am also eventually going to get aftermarket A-arms, which kind does everyone recomend? If I change to say a +2/+1 A-arm, what else do I have to change to keep the front and rear geometry the same? I am going to build my own track and I want to corner better and make my jumping more comfortable on the landings.
Old Apr 12, 2000 | 05:16 PM
PEDRO's Avatar
I run the +2+1 a-arms with a lonestar axle.This makes the front and rear very close to the same width.The axle is really just +1 on each side but my wheels are off-set enough to give it the width.I havnt been able to roll it yet.I also run TCS in the front.The shocks are unbelievable.They were works at first and they stunk.After TCS got them they totally changed them.TCS also has much bigger cans than works which allows for less fade.I also put a set of Blaster pegs on it.This puts a little more weight at the rear so your using your body instead of your arms to keep the front end up.This is cheaper than a shorter swing arm that would do about the same thing.This combination of parts pegs lower and back,wider front end,longer wheel-base,wider rear gives you a weight bias as good as a 250r if not better.The TCS shocks are also nice for getting low to the ground with no preload system which also allows you to keep all your travle no matter how low you set your front end off the ground.Works shocks cant do this.Hope this helps.You'll have to use a blaster shift lever and shorten a banshee brake petal.
Old Apr 12, 2000 | 06:23 PM
Banshee28's Avatar
Is there a specific best place to buy the shocks from? Like CT racing, Graydon proline, or K and K?
How long will it take
Old Apr 12, 2000 | 06:24 PM
Banshee28's Avatar
By the way thanks for the info Pedro, I appreciate the help!
Old Apr 21, 2000 | 09:45 AM
PEDRO's Avatar
I recieved just about all my suspension through Denton Racing.Denton is located just a few blocks away from TCS.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
