87 octane?
Old Jan 24, 2003 | 06:21 PM
Razorcat's Avatar
Default 87 octane?
Anyone run regular 87 octane pump gas in their ds650? Friend of mine has a 50 gal. tank on his truck that he uses to fuel his prairie 650 and airplane. Was wondering if I could use 87 octane in my brand new stock ds....btw it is still in the break in period. thanks for any input [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 24, 2003 | 06:55 PM
BajaDS650's Avatar
Default 87 octane?
I wouldn't use it. They do recommend I think at least 92+octane. Why not just spend the extra $.20 a gallon and be safe?? I'm sure it would run, but mabye not like it is suppposed to. As they always say....It's better to be safe, than sorry! JMHO
Old Jan 24, 2003 | 07:02 PM
hoover650's Avatar
Default 87 octane?
I ran 87 once..........your bike will not tolerate 87 very well. It will cough, spit , sputter and miss. Be good to your bike and run around 90-92
Old Jan 24, 2003 | 08:40 PM
lilnotts's Avatar
Default 87 octane?
i run 87 in mine and it runs fine, but i would 91 during break in just to be sure
Old Jan 24, 2003 | 11:40 PM
FastYellow650's Avatar
Default 87 octane?
i only ran 93 octane until i went to methanol, im not sure what would happen with running with the lowwer octane fuel, i wouldnt try it with your $6000 investment
Old Jan 25, 2003 | 12:29 AM
BlackHawk's Avatar
Default 87 octane?
The octane rating is the fuels resistance to burning from heat I believe. If you run too low of an octane, your gas will burn before the spark. This condition is known as pre-ignition, pinging, pre-detonation and a half of a dozen other names. Someone else who REALLY knows can tell you what the risks are, however I know it isn't a good thing. I can see why you would want to run the 87, however I would suggest the 91+ as recomended by the mfr. If you really want to use some of that 87 though, you could mix in a gallon or so of race gas to boost the octane level a little. I'm not sure if that really works but it sounds like a good idea.
I had an older car with 160k miles on it that was starting to ping due to carbon build up on the pistons, I had to run 91 octane otherwise it was even more gutless & just finicky than it started out.
Old Jan 26, 2003 | 03:22 AM
lilnotts's Avatar
Default 87 octane?
well wat are the stock compression ratios for a rappy n a ds?
Polaris-400
Aug 19, 2015 02:20 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
