Info Request - Spark Plug Wire on Raptor
Old Jan 29, 2003 | 08:31 PM
NotuRaptor2's Avatar
Default Info Request - Spark Plug Wire on Raptor
Hello all, I need some help.
My 2001 "OneRide" Raptor just started breaking up at higher RPMs in any gear. It won't stall completely out but I won't be winning any races. Changing the spark plug has at least momentarily solved the problem. If I fouled the plug then it will be the first one on a four stroke in the last three years. One thing I noticed (besides that it is running rich) is that the wire that goes into the plastic spark plug boot seems to only be held in place by a rubber boot. Is this correct or did my spark plug wire break off where it connects to the spark plug boot?
Thanks for your help,
NotuRaptor
Old Jan 29, 2003 | 08:37 PM
I looked at the diagrams at www.riva-yamaha.com. I guess it is supposed to be separated. I am surprised the wire doesn't wiggle loose and cause more misfires. I can easily pull my wire loose up to 1/2". Oh well, I guess I will see how it goes next time out.
/NotuRaptor
Old Jan 29, 2003 | 08:38 PM
warrior007's Avatar
I had the same problem twice, once was the plug (would run great for a minute or 2 then die at any give higher RPM)
and once was the parking brake sensor.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
WilliamBos
Sep 30, 2015 08:08 AM
DOC HOLIDAY
Jun 15, 2015 05:00 PM
Ask the Editor
Jun 3, 2015 04:16 PM
sae156
Jun 3, 2015 01:45 PM
