blaster front sprocket
Old Feb 2, 2003 | 09:36 AM
bigworm's Avatar
Default blaster front sprocket
hey guys if i buy a new chain and sprocket set will the stock length chain be long enough to go from a 13t to a14t front all new of course also what are the benifits to buy the more expensive oring chain or is standard chain fine
Old Feb 2, 2003 | 10:50 AM
Ernie660R's Avatar
First of all the stock chain length will not be long enough when you add a tooth larger front sproket. The o-ring chain will last a lot longer than the other one.
Hope this helps.
Old Feb 3, 2003 | 12:54 PM
DSG's Avatar
DSG
I have a 03 Blaster & changed the front sprocket to a 14 tooth, the stock chain will work, you just have to adjust it all they way out, PS you loose a lot of low end, it,s like starting out in 2nd with the stock sprocket.
Bratman2
Aug 6, 2022 01:42 AM
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
