Front sprcket went.
Old Feb 3, 2003 | 12:50 PM
02Raptorguy's Avatar
Default Front sprcket went.
This weekend I stripped all the teeth on the front sprocket in a drag race. Now I’ve got an oil leak. Does the seal on the inside of the sprocket usually go out when this happens? I'm worried I've done major damage after seeing the oil leak. Any help would be great.
Old Feb 3, 2003 | 03:18 PM
Ernie660R's Avatar
Well what ever you did, doesn't sound good. It could have cracked the case
Old Feb 3, 2003 | 03:32 PM
RaptorRcR's Avatar
The o-ring that seals the sprocket shaft might have been pinched or torn. It is a common problem..Ive seen it happen many times. Luckily if it is the o-ring, it's a very easy fix. If you cracked the bearing, which I doubt you did..you would have to split the cases to replace that. Take off your sprocket and check it out. I'd say you just messed up the o-ring.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
