Need info on DS mods and maintenance
Old Feb 4, 2003 | 11:08 PM
racerx5x5's Avatar
Default Need info on DS mods and maintenance
Would like any tips on maintenance and mods ? Have 2000 DS650
Old Feb 4, 2003 | 11:10 PM
JMAC650's Avatar
Pipe, air filter, jets, & CDI box.
Old Feb 4, 2003 | 11:23 PM
racerx5x5's Avatar
Is it a big change?
Old Feb 4, 2003 | 11:43 PM
JMAC650's Avatar
The DS responds well to those minor mods. You should feel a big difference in power and response.
Old Feb 5, 2003 | 10:58 AM
HillbillyDS's Avatar
I'll second that, very surprising results with just these bolt on's. If you can get away without an airbox, get the K&N mounted on the carb.....breathes much better plus no worries of stock airboot collapsing on you under arduous acceleration.
Old Feb 5, 2003 | 02:25 PM
KMDuner's Avatar
I have just bolt ons and I dynoed 49.66 HP
Old Feb 8, 2003 | 11:00 PM
brad650's Avatar
o yeh, responds awsome to little mods!
Old Feb 10, 2003 | 04:00 AM
Hightower's Avatar
maintenance - do everything the owners manual recommends as often as it says. Inspect all that stuff. If you don't have a manual, get one. And get the shop manual if you plan to work on it yourself - saves a lot of hassles, headaches, and questions.
Check for axle play before every ride - riding with a loose axle nut can tear stuff up.
Keep the chain adjusted right - if it comes off it can tear a hole in the case.
I like put mine away ready for the next ride - all checks done post ride, cleaned and lubed - chain included, ready to go. All I do the morning of the ride is confirm oil level and antifreeze level, and check tire pressures.
Maintenance is part of the fun of riding and owning a bike, gotta love it all.
dannytas
Sep 26, 2017 06:31 PM
buddieboy
Dec 9, 2016 05:50 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Sep 23, 2015 06:23 AM
