Zilla Wheelie Bar
Old Feb 5, 2003 | 04:57 PM
ZillaRider02's Avatar
Default Zilla Wheelie Bar
I am thinking of adding a wheelie bar to my LT500 for sand dragging. I have a stock swingarm and was thinking of attaching the bar to the 4 large bolts that go through the swingarm and carrier. Anyone have a Zilla wheelie bar? Any ideas for one?
Old Feb 5, 2003 | 09:54 PM
Zilladaddy500's Avatar
I have that same set up.Work's good,but a pain to remove.Your going to have to get longer bolt's.At least I had to.I made mine so I could either raise it or lower it,depending on the track.
Old Feb 5, 2003 | 10:05 PM
ZillaDaddy, I would love to see some pics of your setup if possible. Did you put a skid or a wheel on the end of it? Thanks.
Old Feb 5, 2003 | 10:43 PM
Sorry not yet.DO-NOT use a skid plate,it can dig in and steer ya like a boat rudder.Go with the wheel.1/4 inch steel is what I used to make the bracket's to hold the wheelie bar.3/4 square tubing and a wheel,less friction that way and won't slow you down as much.
Old Feb 5, 2003 | 10:52 PM
Thanks for the info. Do you have 4 bars going into the wheel or just 2? I'm guessing you need to set the height of the bar with someone on the bike.Thanks.
Old Feb 5, 2003 | 11:21 PM
3 bar's go to the wheel.Make sure the weld's will hold.Do not rush making your bar,I did one time and I'm lucky to be alive or that I didn't get seriuosly hurt.The weld's broke from the top bracket leaving the bar bouncing down the track,if the front would have come up and over,it would have went threw my back.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex G.
Sep 19, 2015 06:34 PM
Folkzilla
Aug 21, 2015 12:36 PM
black_thunder
Jul 26, 2015 09:23 PM
coolguy420
Jul 10, 2015 01:17 AM
