valve adjustment??
Old Feb 6, 2003 | 07:00 PM
Mudracer300's Avatar
Default valve adjustment??
does anyone know where i can find out how to adjust the valves on my scrambler with out having to buy the repair book??
thanks
Old Feb 6, 2003 | 07:35 PM
ftwflh's Avatar
They set at .006 on both.
Old Feb 6, 2003 | 10:08 PM
i have to take the cover off the top of the engine right?? its got like 10 little bolts holding it on?? then i just check the clearnce
thank you
Old Feb 6, 2003 | 11:28 PM
BigBadScrambler's Avatar
You take the cover off and remove the timing inspection plug from the recoil houseing. Make sure the piston is in top dead center. Verify this by observing the "T" mark aligned with the pointer in the timing inpection hole. At TDC, there should be clearance in all valves. Insert a .006 feeler gauge between end of intake valve stem and clearance adjuster screw. Use a 10mm wrench ans screwdriver to loosen the lock nut and turn the screw until there is a light drag on the feeler gauge. Hold screw and tighten the lock nut.Repeat for the other intake valve. Recheck the clearance. For the exhaust, insert a .006 feeler gauge between the end of valve stem and adjuster screw for BOTH valves because the share a rocker arm. Loosen the nut and adjust with the screw. Bothe gauges should remain during the adjustment. Then just recheck everything and put it back together. Hope that helped
Hey, this is my 100th post
[img]i/expressions/face-icon-small-smile.gif[/img]
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
