Mudlite tire clearance?????
Old Feb 8, 2003 | 08:26 PM
deetheman's Avatar
Default Mudlite tire clearance?????
I just put 27-12-12 mudlites on the back of my Rubi and I only have like a 1/2 inch clearance at the bottom of my mudguard. Has anyone had this problem? Do you have to trim the mud guard?
Thanks,Dee
PS I have a lift kit.
Old Feb 13, 2003 | 02:12 AM
swampdonkeykiller's Avatar
From what I have heard, you need to eitheir trim or remove the mudguard on the muffler to make 27" + tires to fit without coming close to or rubbing.
Old Feb 13, 2003 | 02:27 PM
Harw's Avatar
That is why you use a 27X10X12 on the back. The 12 in. wide tire when put on a 7.5 rim makes the tire taller than it should be. Right now your rear tires are taller than your front.
Old Feb 14, 2003 | 04:09 PM
deetheman's Avatar
I don't have a problem w/ the tire hitting the exhaust. I've got about 3" clearance there. Its at the bottom of my mud guards.
My rear tires are not taller than the front they are 1/2" shorter.
Dee
Old Feb 16, 2003 | 03:26 PM
nick01's Avatar
You should be fine, but if it does start to hit the mud guard just trim it up a bit.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
