compression leak down test
Old Feb 9, 2003 | 02:02 PM
FastYellow650's Avatar
Default compression leak down test
this is a two part question
one, can you get a tester to fit on the 650, i guess the plug size is smaller than a car plug, and i havnt been able to find any set up to work on the bike
two, if i do find one what is a good leak down precentage
thanks
Old Feb 9, 2003 | 04:10 PM
jeffnrivercity's Avatar
Most good leakdown testers have the right adapters..I used a MAC and it had the right adapter
I have heard 3 percent or less?...for the DS,
You might have to pull the valve cover..to make sure the decompression lever is not engaged(when at TDC)
Jeff
Old Feb 9, 2003 | 04:16 PM
derbyking's Avatar
you can get adapters from mac,matco,snap on ect.mac or matco are cheaper. my rappy ckd at 4%
Old Feb 9, 2003 | 05:08 PM
ok thanks, my snap on guy comes around on wendesday and ill see if he has one one truck, i dont like using the mac, or matco due to the salesman who come to our shop, there idiots, i know the tools are good, but these guys propbably dont even know what a compression tester is
Old Feb 9, 2003 | 05:33 PM
dsmike's Avatar
2% is prefect. 10% needs overhauled. 20% no power.
Old Feb 9, 2003 | 11:38 PM
The first leak down test I did..I didn't lock the crank..and I got a false reading..
I went back and re-tested and had 20%...with in seconds it blew a good amount of oil on the floor(out of the breather)
Jeff
slowgsxr97
Mar 18, 2022 03:40 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
NatePerz
Jul 27, 2015 03:27 AM
southbayman
Jul 24, 2015 09:30 AM
